-   -   Stirred tank with baffles simulation using single rotating reference frame (http://www.cfd-online.com/Forums/fluent/27537-stirred-tank-baffles-simulation-using-single-rotating-reference-frame.html)
M.Zhou March 4, 2000 09:55
hi,
I want to know --Can I use single rotating reference frame to simulate stirred tank with baffles? In this method the tank wall and the baffles are defined counter rotating walls. Therefore I need not use multi-frame of reference. Can I do this? Please tell me. Thinks.
M.zhou
Sung-Eun Kim March 5, 2000 16:01
Re: Stirred tank with baffles simulation using single rotating reference frame
I'm afraid you can't use a single rotating frame of reference. You should use either multiple rotating frames (MRF) or sliding mesh capability in FLUENT. The MRF is a convenient, much cheaper alternative to the full transient sliding mesh capability. Please refer to User's Guide.
