-   -   Bounding frames increments (http://www.cfd-online.com/Forums/fluent/27605-bounding-frames-increments.html)
Ricky Wong April 3, 2000 11:43
Hi
Does anbody know how (if possible) you can change the axes major and minor intervals on a bounding frame when your composing a scene!... if anyone knows if its possible a swift posting would be appreciated as I need it for a seminar the post-graduates are running on Friday 7th March.
Thanks
Chris April 5, 2000 14:08
Re: Bounding frames increments
Try playing with these variables:
;; outline and ticks
(ticks/color/background "dark grey" string)
(ticks/color/major "white" string)
(ticks/color/minor "gray" string)
(ticks/major/weight 1 real)
(ticks/major/npts 5 integer)
(ticks/minor/weight 1 real)
(ticks/minor/size 0.01 real)
(ticks/major/size 0.02 real) by using the cxsetvar function, eg:
(cxsetvar 'ticks/major/npts 8)
(cxsetvar 'ticks/minor/size .005) then redisplay the scene.
Ricky Wong April 5, 2000 15:40
Thanks Chris, but I don't know how to set those variables? I've been through the text interface menus and I can't find them. Could you tell me how to set them please?
Thanks again
Ricky
Chris April 6, 2000 08:55
The last two lines I posted were examples of how to set them. For example, to set the number of major divisions to 8 you would type the following line into the text input area:
Then you would click on the Display button on Bounding Frame dialog box (accessed via the Frame Options... button on the Scene panel) to see what effect it has.
