How to plot Cp of 3D wing section
Old   April 19, 2000, 20:21
Default How to plot Cp of 3D wing section
Wason
Dear all,
How can I plot the Cp of 3D wing sections/slender symmetry,if the flow field was meshed with unstructure mesh?
Thanks
Old   April 25, 2000, 11:46
Default Re: How to plot Cp of 3D wing section
Sung-Eun Kim
You should generate "surfaces" (FLUENT terminology meaning curves in 2D and surfaces in 3D) first. Iso surface and iso-clip are what you might need.
Old   April 25, 2000, 20:15
Wason
Thank you, Kim, Yes I can plot the Cp around a 3D Wing section according to what you told me, but, there are two lines(up wall & down wall)which are connected really, How can I distinguish them?
Wason
Old   July 11, 2000, 17:44
Oliver
Hi
Cp at a stagnation point is one, leading edge and the second "stagnation point" is the trailing edge. therfore you can split your suction and pressure surfaces from this.
Hope this helps
oliver
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
making wing section cuts in Fluent? mimi FLUENT 0 May 8, 2007 03:42
Icon plot of section Luke Siemens 2 May 31, 2006 11:12
Pressure plot by wing slice Matt FLUENT 1 November 26, 2005 20:04
