-   -   How to plot Cp of 3D wing section (http://www.cfd-online.com/Forums/fluent/27637-how-plot-cp-3d-wing-section.html)
Wason April 19, 2000 20:21
Dear all,
How can I plot the Cp of 3D wing sections/slender symmetry,if the flow field was meshed with unstructure mesh?
Thanks
Sung-Eun Kim April 25, 2000 11:46
Re: How to plot Cp of 3D wing section
You should generate "surfaces" (FLUENT terminology meaning curves in 2D and surfaces in 3D) first. Iso surface and iso-clip are what you might need.
Wason April 25, 2000 20:15
Thank you, Kim, Yes I can plot the Cp around a 3D Wing section according to what you told me, but, there are two lines(up wall & down wall)which are connected really, How can I distinguish them?
Wason
Oliver July 11, 2000 17:44
Hi
Cp at a stagnation point is one, leading edge and the second "stagnation point" is the trailing edge. therfore you can split your suction and pressure surfaces from this.
Hope this helps
oliver
