Drag Coefficient(Cd) of circular cylinder
Old   June 4, 2000, 04:28
Default Drag Coefficient(Cd) of circular cylinder
Ram
Hi
I am trying to find Cd value of flow past circular cylinder using Fluent. But I end up with wrong results! Has anybody here worked on this case and got good results?
Thanks in advance.
Old   June 4, 2000, 12:34
Default Re: Drag Coefficient(Cd) of circular cylinder
John C. Chien
(1).What kind of wrong results are you getting? 2.0, 0.1?(2). What good results are you expecting to get? (3). Cd=Drag/(A*0.5*Rho_freestream*U_freestream*U_freestream), A is Diameter*unit thickness, Drag=Viscous Drag at the surface + pressure drag on the surface. (4). Check the setting of the Reference values or conditions somewhere in GUI and make sure that they are set properly. (5). Always check the flow field first. Plot the streamline and check whether the solution is reasonable or not.
Old   June 4, 2000, 14:32
Ram
Thanks for your helpful comments.
I have noticed that I failed to change the area value in the Reference values list. After modifying the Area value, the Cd values are coming okay.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
About drag coefficient of 2D circular cylinder! Haoyin Shan FLUENT 0 May 6, 2007 23:50
Circular cylinder drag at high Re Anton Lyaskin Main CFD Forum 0 January 14, 2003 04:48
