Home > Forums > FLUENT
Patching the solution
Old   June 6, 2000, 02:33
Default Patching the solution
Balu
Hi
Could somebody tell me about patching the solution? I referred the online help in fluent but could not get clear idea about it. Thanks.
Old   June 6, 2000, 11:18
Default Re: Patching the solution
Brant Aggus
"Patching" the solution is supplying an initial value for a given property that is different from the initial estimate for steady state. This is really useful for combustion reactions in that if you need a "spark" to light a flame, you can just patch a temperature value high enough for ignition into the cells, and it will ignite it. You initialize the solver first, then the patch option should become available in the menu. Ignition is the only thing I have used it for, though.
Old   June 8, 2000, 15:45
LW
For unsteady state heating or cooling, you may be able to use patching to define initial temperature.
Thread Tools
Trackbacks are On
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 169 December 28, 2015 15:07
Solution converged, and then diverge again. jrg FLUENT 2 April 1, 2013 23:10
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Mesh independent solution CFX Begineer CFX 0 October 27, 2002 11:54
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
