Heal real faces command.
Old   June 16, 2000, 11:21
Default Heal real faces command.
Jack Keays
Hi guys,
I know, I know, I gotta stop asking questions! I am wondering what the "Heal real faces" command means. Also, do the convert real faces and real edges command actually convert virtual geometry to real geometry?? It would be great if they did!
Jack.
Old   June 19, 2000, 17:12
Default Re: Heal real faces command.
Shyam Kishor
Healing is designed to detect and fix accuracy problems of real (ACIS) geometry. In brief, it allows you to repair bad geometry. There are three main phases of Healing process a) Geometry Simplifications b) Stitching and c) Geometry building. Gambit 1.3 (soon to be released) also allows user interaction on its phases and their tolerances. Please check Gambit documentation and/or contact your Fluent Support Engineer for details.
Yes, Convert faces & edges commands allows you to convert non real(virtual/faceted) geometry to real. Moreover, it maintains existing mesh as well as topological connectivity. Face convert requires non real faces to have a mapped mesh on it. Gambit 1.3 also allows volume conversion. Again, please contact your Fluent Support Engineer for details.
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 16:08
0 or 0.0 in udf wlt_1985 FLUENT 5 June 29, 2011 16:27
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
