C_NNODES UDF 'function' problem
With a view of patching values at a set position into a cell I need to check that they are exactly bounded by the cell nodes. First I need to see how many nodes there are (by using C_NNODES 'function') so I can use the NODE_X, ... function to find the position of the nodes. Hence I've run into problems at step 1 (see the code below) where I'm trying to use C_NNODES, with the following error resulting at trying to compile the interpreted UDF:
cpp -Ie:\fluent.inc\fluent5.2/src -Ie:\fluent.inc\fluent5.2/cortex/src -Ie:\fluent.inc\fluent5.2/client/src -Ie:\fluent.inc\fluent5.2/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" e: est.c Error: e:\test.c: line 23: non-integer subscript expression: unsigned char. I've supplied the test code below, where am I going wrong? I think problems will develop for me when using the NODE_X function because I don't know where the heck the 'node' pointer is going to be passed from, I just want to see how to use C_NNODES first. PS: Please keep in mind I'm quite a novice when it comes to using C. /************************************************** *********************/ /* interpreted UDF for patching values at initialisation */ /************************************************** *********************/ #include "udf.h" DEFINE_INIT(my_init_function, domain) { cell_t c; Thread *thread; real xc[ND_ND]; thread_loop_c (thread,domain) { begin_c_loop_all (c,thread) { C_CENTROID(xc,c,thread); if (sqrt(ND_SUM(pow(xc[0] - 0.5,2.), pow(xc[1] - 0.5,2.), pow(xc[2] - 0.5,2.))) < 1.7) { /* checks whether inside spherical test region of interest - just to check if c and thread work in other functions (here C_CENTROID) and to limit number of points to print out in GUI */ int num; num = C_NNODES(c,thread); printf("num = %d\n", num); C_U(c,thread) = 1.; } else C_U(c,thread) = 0.; } end_c_loop_all (c,thread) } } |
Re: C_NNODES UDF 'function' problem
That is a bug. It should work OK as is for compiled UDFs.
To make it work in the interpreted UDFs, change the line: num = C_NNODES(c,thread); to read: num = cell_type_nnodes[(int)C_TYPE(c,thread)]; Chris |
Excellent, thankyou!
