C_NNODES UDF 'function' problem
Old   June 21, 2000, 03:55
Default C_NNODES UDF 'function' problem
Matthew Brannock
With a view of patching values at a set position into a cell I need to check that they are exactly bounded by the cell nodes. First I need to see how many nodes there are (by using C_NNODES 'function') so I can use the NODE_X, ... function to find the position of the nodes. Hence I've run into problems at step 1 (see the code below) where I'm trying to use C_NNODES, with the following error resulting at trying to compile the interpreted UDF:
cpp -Ie:\fluent.inc\fluent5.2/src -Ie:\fluent.inc\fluent5.2/cortex/src -Ie:\fluent.inc\fluent5.2/client/src -Ie:\fluent.inc\fluent5.2/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" e: est.c
Error: e:\test.c: line 23: non-integer subscript expression: unsigned char.
I've supplied the test code below, where am I going wrong?
I think problems will develop for me when using the NODE_X function because I don't know where the heck the 'node' pointer is going to be passed from, I just want to see how to use C_NNODES first.
PS: Please keep in mind I'm quite a novice when it comes to using C.
/* interpreted UDF for patching values at initialisation */
#include "udf.h"
DEFINE_INIT(my_init_function, domain) { cell_t c; Thread *thread; real xc[ND_ND];
thread_loop_c (thread,domain)
begin_c_loop_all (c,thread)
C_CENTROID(xc,c,thread);
if (sqrt(ND_SUM(pow(xc[0] - 0.5,2.),
pow(xc[1] - 0.5,2.),
pow(xc[2] - 0.5,2.))) < 1.7) { /* checks whether inside spherical test region of interest - just to check if c and thread work in other functions (here C_CENTROID) and to limit number of points to print out in GUI */
int num;
num = C_NNODES(c,thread);
printf("num = %d\n", num);
C_U(c,thread) = 1.;
else
C_U(c,thread) = 0.;
end_c_loop_all (c,thread)
Old   June 21, 2000, 10:16
Default Re: C_NNODES UDF 'function' problem
Chris
That is a bug. It should work OK as is for compiled UDFs.
To make it work in the interpreted UDFs, change the line:
to read:
num = cell_type_nnodes[(int)C_TYPE(c,thread)];
Chris
Old   June 21, 2000, 22:46
Matthew Brannock
Excellent, thankyou!
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
UDF parse error at profile function line Wiggy Fluent UDF and Scheme Programming 1 July 27, 2009 15:59
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
