-   -   neutral file (http://www.cfd-online.com/Forums/fluent/27750-neutral-file.html)
Sebastien DANIEL June 26, 2000 10:43
neutral file
Hey all,
How can I convert neutral file (".neu") without open tfilter to be read with fluent 5.3?
Thank you in advance.
Sebastian DANIEL
Chris June 26, 2000 12:09
Re: neutral file
I am not sure I understand the question, but if you have a gambit, fidap, or patran neutral file (which are all different but commonly have the .neu suffix) you can either use the File|Import menu in fluent (which invokes tfilter) or you can run tfilter by hand from the command line.
If you don't want to run tfilter (why not?), I suppose you could write your own conversion program. Seems like a fairly masochistic approach, though.
Sebastien DANIEL June 27, 2000 06:01
Re: neutral file
Thank you for your help. If I understand right, I can launch tfilter directly with fluent.
I tried with command line but my PC is quiet slow and unstable thatwhile I searched an other way.
