June 1, 2000, 07:23 |
compiling UDFs in NT
Hello All,
I am learning how to set up and use UDFs in a Windows NT system. I was able to write and use some codes and I could only work on the interpreted version. But I just can't compile any of my codes. Help on User's Manual seems to have little to do with the files I find in different versions. In version 5.0 I simply can't find the files Makefile (executable) and makefile (source) that are declared to be in the path ..\Fluent.Inc\Fluent5.0\src\. Anyways I can't find them anywhere. In Version 5.3.18 (and I state that the manual is the same!!!) the compiling logic is different. I CAN find a file called makefile (a source code) but I am not supposed to modify it. I should edit another file called user_nt.udf, in which I should set the name of the udf, the version (2d-2dd-3d-3dd) and parallelism. Everything (makefile-user_nt-udffilename.c) has to be in the same target directory. And then I have to run NMAKE. After having done all that, I get the message: you need to define the environmental variable Fluent_Inc. Well, after having done that... (i did it in user_nt) I simply get: don't know how to make '..\..\src\udffilename.c' So do I. Thanks all |
June 26, 2000, 11:17 |
Re: compiling UDFs in NT
Hello! You can find a special manual on http://www.fluentusers.com for fluent 5.2 where the way to compile udf on NT is described. It seems to work.
Good luck Eric |
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) | Ali.beh | Fluent UDF and Scheme Programming | 3 | August 27, 2018 04:22 |
Problems compiling UDFs under SuSE 10.2 | George | FLUENT | 1 | February 21, 2007 08:36 |
Compiling UDFs under Windows XP | Hannah | FLUENT | 3 | February 13, 2005 08:16 |
Compiling and Running UDFs on an IBM Power3 | S. Hollman | FLUENT | 0 | January 6, 2005 11:23 |
Compiling UDF's in Fluent 6.0 | ramesh | FLUENT | 2 | June 11, 2004 17:34 |
