UDF for looping over nodes in cells.
Like Tree1Likes
  • 1 Post By Chris
Old   June 29, 2000, 05:11
Default UDF for looping over nodes in cells.
Malcolm Wallace
I'm trying to develop an interpreted UDF (under Windows NT) that will ultimately check to see whether cells lie on a specified plane or not (so that I can then access cell centre values on that plane). However, in order to do this, I need a UDF that can access the coordinates of all nodes associated with a particular cell. The UDF included below is designed to run as a 'Chip-exec' command, but unfortunately I have problems getting it to compile. I suspect I have the same sort of problem as the C_NNODE item posted here recently. Can anyone shed some light as to why the UDF below should not compile? The error which comes up is:-
cpp -IE:\FLUENT.INC\fluent5.3/src -IE:\FLUENT.INC\fluent5.3/cortex/src -IE:\FLUENT.INC\fluent5.3/client/src -IE:\FLUENT.INC\fluent5.3/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" e:\fluent.inc\libudf\src\cinfo3b.c Error: e:\fluent.inc\libudf\src\cinfo3b.c: line 19: non-integer subscript expression: unsigned char.
This must refer to the 'n' contained in the line 'c_node_loop(c, t, n). What do I need to do before the compiler will recognise this line? Any help will be greatly appreciated!
Malcolm W.
mwallace@nel.uk
************************************************** ************************* #include "udf.h"
extern Domain *domain; void cinfo3();
void cinfo3() {
cell_t c;
Thread *t;
Node *v;
int n;
real yvalue;
thread_loop_c(t, domain)
begin_c_loop_all(c, t)
v = CELL_NODE(c, t, n);
yvalue = NODE_Y(v);
end_c_loop(c,t)
Old   June 30, 2000, 09:44
Default Re: UDF for looping over nodes in cells.
Chris
You are right, it is the same problem. Change the c_node_loop(c,t,n) line to read
for(n=0;n<cell_type_nnodes[(int)C_TYPE(c,t)];++n)
Also you need to change CELL_NODE(c,t,n) to C_NODE(c,t,n).
ali_karimi likes this.
Old   June 30, 2000, 15:01
Chris
Hmm. That didn't work at all. Apparently it didn;t like the less-than symbol. Lets try again, but where it shows LT you want to use the less-than sign (the ampersand lt semicolon doesn't work either...).
You need to replace the c_node_loop(c,t,n) line with:
for (n=0; n LT cell_type_nnodes[(int)C_TYPE(c,t)]; n++)
Old   July 3, 2000, 09:22
Malcolm Wallace
Problem solved! Thanks Chris.
Malcolm
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
export nodes, cells and heat transfer coefficients Ademar Cardoso FLUENT 0 September 13, 2005 17:22
Setting pressure value for specific cells, UDF Amir FLUENT 2 September 1, 2005 18:59
Set up the velocity of some cells in the UDF. Fluenter FLUENT 6 September 27, 2004 01:30
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
