Home > Forums > FLUENT
About MRF--Rotation flow
Old   July 4, 2000, 03:18
Default About MRF--Rotation flow
wason
Hi all,
I am using MRF model to simulate 3d a centrifugal pump. The flow cab be assumed steady. I have used two reference frames, one is stationary ,and the other is rotation(which include the blades). But the deference between the numerical results & experimental results is about 30%, What's the reason? is it proper for me using the MRF? I would appreciate if anybody can give me advice. Thanks!
Wason
Old   July 6, 2000, 03:44
Default Re: About MRF--Rotation flow
Ahmet AÇIKGÖZ
Hi Wason, What are your BC's? How many iterations you have made? Convergence? Which model did you use?
Old   July 6, 2000, 20:02
wason
Thank you for your question, What are your BC's? Inlet is velocity Outlet is outflow Rotation Zone is using Ratation flow
How many iterations you have made? About 4000 iterations
Convergence? yes, Which model did you use? Segregated , SimpleC & Simpler
Thanks again
Wason July 7
Old   July 7, 2000, 03:23
Ahmet AÇIKGÖZ
Hi Wason, I prefer to use pressure inlet and pressure outlet equal to zero if I don't know the flow rate of the turbomachine and I use RNG k-e model. Under these conditions, you should find out flow rate almost equal to the experimental results. On the other hand presure head of the turbomachine depends on your geometry. To make better discussion about pressure head, I have to see your geometry.
Ahmet
Thread Tools
Trackbacks are On
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Rotating objects in flow using MRF Kyle FLUENT 1 December 5, 2005 20:29
Rotation flow calc. II. Andy Christian Main CFD Forum 2 April 10, 2003 04:06
