How to define periodic boundary conditions at Flu
Old   July 21, 2000, 08:58
Default How to define periodic boundary conditions at Flu
Wang
Hi, I have a problem when I use FLUENT5.3. I want to change two symmetry boundary conditions to a couple periodic boundary condition. However, I can not find this MENU in Flunet5. Could you tell me how to change them? Has FLUENT5 this function?
Old   July 21, 2000, 18:37
Default Re: How to define periodic boundary conditions at
Pierluigi Allegro
You mast use the command line with these istructions:
:define
:bc
:modify-zone
:make-periodic
then answer the questions. By.
Old   July 24, 2000, 05:40
Wang
Could you tell me some details?
Old   August 25, 2000, 22:07
Default Merge zone in FLUENT
Harry
1. i've a problem using fluent 5.1. i want to model 1 full mixing tank, but because it's difficult to mesh full tank, i draw 1/4 tank and then copy and rotate it in TGRID, and merge the zone i want. everything is ok in TGRID, but after i imported to fluent, fluent separate the zone. then i try use TFILTER. it's fine, but after i imported that mesh file to fluent again and using merge zone, theres a message unable to merge thread. zone X and Y doesn't match. What wrong with that????(i think i can merge any zone without restrictions).
2. can u tell me, how to add a new boundary cond type of Discrete Phase Modelling (escape,trap,reflect). i want to make myself.
Old   August 29, 2000, 21:36
Harry
maybe i can tell you the other way. you can back to your gambit. if you've mesh your volume, remove mesh first and then click link mesh, on mesh surface. click surface to be linked and point of linking. then gambit will draw a vector on the edge of your surface. then click adjacent surface (shadow surface), click the point of the 2nd surface, and then a point. if direction of the vector isn't same, click reverse. then you can mesh your volume. (see Fluent volume 1 on periodic boundary condition f or detail)
HELP,how to define the periodic boudary conditions using the icem mesh? dada1204 FLUENT 2 May 1, 2012 17:06
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Problem with using periodic boundary conditions Sun FLUENT 0 January 14, 2011 09:47
Pitchwise periodic boundary conditions aqib Main CFD Forum 0 November 7, 2010 14:00
Periodic Boundary Conditions ! Krik FLUENT 1 March 22, 2005 18:50
