Non-overlapping portion in non-conformal meshing
Hi all
In my 3D simulation, Fluent is not allowing the flow across the non-overlapping portion of the interface that used for non-conformal meshing. What can I do overcome this situation? Thanking you, Remesh. |
Re: Non-overlapping portion in non-conformal meshi
It has changed the non overlapping portions to wall zones. That is why there is no fluid flow across that portion. When you create a new mesh you can spilt the wall zones at the point where the non-overlapping portion begins
Hi Michael,
Is it true that the non-overlapped portion of the mesh has been transformed to wall? In that case, can i change the automatically generated wall to some other zone type so that the flow will not be affected? Thanks, Ramesh. |
