how to import ASCII data to Gambit?
Old   July 22, 2000, 04:21
Default how to import ASCII data to Gambit?
Vlad
Hi All, I am looking at the turbulent flow over different 2-D profiles. Often, it would be (much) easier to make a simple ASCII file with coordinates of a profile (edge) and then import these data to Gambit than to draw this surface in Gambit. I tried to File->Import->ASIC - didn't work. Does somebody know how to do it? Thanks
Old   July 22, 2000, 05:42
Default Re: how to import ASCII data to Gambit?
Pierluigi Allegro
Try to check the versions of the acis format file, with gambit1.1 from autocad2000 it works correctly.
Old   July 24, 2000, 09:15
Pavel Strasak
Hi, an ASCII format is not an ACIS format!! The best way for reading an ASCII format with coordinates is to use the journal file. Your journal file must content the right syntax for the command "create vertex", eg. "vertex create coordinates 1 1 1", where 1 1 1 are the value of x,y,z coordinates. Best Regards Pavel
Old   July 24, 2000, 20:21
Vlad
thank you
Old   July 26, 2000, 17:21
Shyam Kishor
Gambit allows import of point data from an ascii file with xyz coordinates. It can automatically create vertices, curves and surfaces. These options are available through File -> Import -> ICEM Input & File -> Import -> Vertex Data. Please contact your Fluent Support Engineer for details.
Importing Gambit data into Fluent Tyred ANSYS Meshing & Geometry 1 April 18, 2009 13:53
Export data from GAMBIT to GAMBIT Sanjay Jain FLUENT 1 April 3, 2008 00:44
Import to CAD - Gambit guest Main CFD Forum 5 November 21, 2002 10:37
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 10:04
Autocad import into Gambit Paul Main CFD Forum 5 July 12, 1999 04:19
