Home > Forums > FLUENT
2D mesh from IGES geom
Old   July 24, 2000, 10:17
Default 2D mesh from IGES geom
John Faragher
I have imported an IGES file to Gambit for a 2D model but the Z coord values are not precisely zero, i.e. entities are not exactly in the x-y plane. When I create a mesh and try to read it into Fluent 2D I get an error message saying "File has wrong dimensions" (presumably 3D instead of 2D). Can I set the Z values to zero somehow? Can I tell Gambit the IGES geometry is 2D? I tried importing a patran neutral file with the 2D option on the import dialog box in Gambit but even then the z-values are not zero.
Old   July 26, 2000, 17:09
Default Re: 2D mesh from IGES geom
Shyam Kishor
At present, Gambit requires all the Z coordinates for a 2d model to be equal to zero within a tolerance. This value is typically 1e-4. So, if || z || < 1e-4 every where, it will write a 2d mesh, else a 3d mesh would be written.
We are considering adding a command that will allow user to transform a 2d model on z=0 plane. For now, one of the two simple workarounds can be used :
1) Export a neutral file from Gambit. Then, import this mesh from a Fluent 2d session. You can also use tfilter fe2ram from a unix command prompt to convert the neutral file to a Fluent mesh file. Please make sure to specify -2d as the dimension.
2) Scale down (move/copy form) the model in Gambit such that || z || < 1e-4 every where. Now mesh exported would be 2d. Once read in solver, scale it up to the original size.
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
