Home > Forums > FLUENT
Printing from GAMBIT
Old   July 24, 2000, 11:17
Default Printing from GAMBIT
Hi all,
I have questions regarding printing from GAMBIT. 1) How to import the model (or part of it) that has been constructed in GAMBIT to Microsoft Word processor. 2) How to print out a hard copy of the Model from GAMBIT. 3) How to print out the windows from GAMBIT.
Thanks ...
Old   July 25, 2000, 12:03
Default Re: Printing from GAMBIT
Kai Kang
choose printing to file option, with the right image format (ie, tiff).
Old   July 25, 2000, 14:07
Dear Kai, Thanks for that piece of information. However, I know that but my question is, is there any other way of doing it. That is, how can I make my geometry and its mesh look like those in GAMBIT tutorials? As if I do it the way you mentioned I cannot change the colour. Moreover, when I printed out it is not clear.
So any help ??
Old   July 25, 2000, 14:43
Kai Kang
Sorry, I did not read you question carefully.
In the geometry operation panel, under faces or volumes there is a change color function (the pie chart button) where you can change selected face/volume colors/shadings as well as associated mesh colors...
In the menu under parameter/Graphics, where a lot of imaging/graphics parameters can be set, such as background color for printing, or factors for display curved surfaces...
I always save it as Tiff images and print directly to the printer. Insert it into other program like Word will change the resolution, powerpoint is better than word for pictures...
You can choose any part(edges/faces/volumes) you want to display by the button on the lower right corner (which is mostly used to turn off mesh display) or changes any of there display mode (wire/shaded/hided).
Hope this helps
Thread Tools
Trackbacks are On
How to open a saved Gambit File? barkan FLUENT 5 September 1, 2012 05:53
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
gambit crashed mbgnfrx2 FLUENT 1 August 13, 2009 03:31
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
