-   FLUENT (
SC HU July 26, 2000 00:38
Dear Sir:
Does the fluent (not Fidap) has the capacity of solving the governing equations in dimensaionless form? Where can I find the information in Fluent's associated manu/references. Is example available?
Jin-Wook LEE July 26, 2000 04:04
I think that every program(or commercial package) can be non-dimensionalized by your selection of velocity, characteristic length, related properties and so on.
Consider the situation of flow in the channel with,
Vin = 10 m/sec, height=2m/sec, length=20m/sec, rho=2kg/m3, viscosity=1.e-05kg/m-sec
You can set the problem by nondimensional form such as,
Vin = 1, height = 1, length = 10, rho = 1, viscosity = 1/Re = (4*10^6)^(-1)
This is nondimensional form. I have experience for the simulation of natural convection in the square cavity by nondimensional form, by Flotran/CFD. I could not find that FLOTRAN/CFD has the capability of solving the governing equations in dimensaionless form in the manual.
So, I think that every code has capability of solving the governing equations in dimensaionless form for most problems.
Hoping that it will be helpful to you. Sincerely, Jinwook
Sung-Eun Kim July 27, 2000 21:58
Unlike some research codes, most multiphysics-based, general-purpose CFD softwares adopt dimensional form of the governing equations. There are many reasons for that. But I think the issue of usability is a major one. And yet, as Jin-Wook pointed out, you can basically do what amounts to using non-dimensional form of the governing equations, by scaling (non-dimensionalizing) both dependent and independent variables and adjusting physical properties so that you have the desired non-dimensional numbers (Reynolds, Prandtl, Rayleigh, etc.).
