Home > Forums > FLUENT
Analysis of wake
Old   August 11, 2000, 03:24
Default Analysis of wake
sameer mohrir
Hello all,
What types of method are used for analysis of wake behind 2D / 3D bodies.
Best regards
Old   August 11, 2000, 09:27
Default Re: Analysis of wake
John C. Chien
(1). Jet and wake are in the same category. (2). Same method applies to the jet and wake. Both are free boundary layer type. (3). Schlichting's book "Boundary Layer Theory" has chapters dedicated to jet and wakes. It is the standard text book for graduate school students. (4). The turbulence model part is a different story. These models may not be applicable to all types of jets and wakes, without adjustment to the coefficients. (round jet, 2-D jet, etc...)
Old   August 11, 2000, 09:35
Kai Kang
Checked out D. Wilcox, "Turbulence Modeling in CFD", there are examples (reviews) showing the different turbulence models applied to jet and wake
Old   August 11, 2000, 09:51
John Cimbala
I did a comprehensive comparison of various turbulence models in the 2-D far wake. Overall, it turns out that NONE of the existing turbulence models does a great job on all aspects of the turbulent far wake. I presented my results at the 10th Symposium on Turbulent Shear Flows, August 1995, beginning on p. 6-25.
Old   August 12, 2000, 00:07
sameer mohrir
Hello
Whether type of flow (i.e compressible / incompressible) will have an effect on wake formation behind any 2D / 3D bodies.
best regards
Old   August 12, 2000, 00:36
John C. Chien
(1). Flow behind a 2-D or 3-D body is rather complex. (2). It is no longer in the conventional wake area. (3). Flow over a body can create a large oscillating separated flow region. And supersonic flow over a body can create a strong shock in front of the body. it will also create complex wave pattern in the separated flow region. (4). At most, the flow behind a body can be viewed as a near-wake problem, which is not conventional wake at all. In this case, far field region can be considered as the conventional wake region, where it has forgotten about the near field effect. (5). There is always a Mach number effect on jet and wake.
Old   August 12, 2000, 03:22
sameer mohrir
Hello John C .Chien
Thanks
sameer mohrir
Old   September 5, 2000, 11:05
Anders Hagberg
I have compared supersonic wakeflow with different turbulence modells. The RSM gave the best results, but it is still far a way from the correct solution.
Maybe you should try an Time- dependent solution
best reegards Anders Hagberg
Thread Tools
Trackbacks are On
Modelling the cross aisle direction of a steel selective rack for model analysis m8rix ANSYS 0 September 20, 2011 10:28
LES post analysis faisal_durr Main CFD Forum 0 July 13, 2011 05:52
3D analysis of Ahmed body Irshad22 FLUENT 0 December 17, 2009 05:33
Cylinder Wake calculation Adam Chapman Main CFD Forum 1 January 30, 2007 13:54
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
