non-positive volumes
Old   August 23, 2000, 05:47
Default non-positive volumes
Javier Fernandez
I am a fluent new user and I have same problems with non-positive volumes. I would like to know if it is posible to repair a mesh whith this kind of troubles by means of the "adapt" menu or I will have to remesh my geometry. Thanks.
Old   August 23, 2000, 10:37
Default Re: non-positive volumes
Sandeep
You can first try and fix this problem inside of the fluent solver by doing a repair-facehandedness command:
grid > modify-zone > rfh
After you do this, see if any negative volumes still show up. If they still do, you will have to go back to the pre-processor and adjust the mesh density.
Old   August 23, 2000, 10:50
Angus Duncan
I have had this problem with tgrid a while back. The repair was simply to save the mesh and then re-read it back into tgrid. A mesh check should then run okay and you can save and export this mesh to Fluent.
If the non-positive volume problem is due to left-handed faces then use this command in the console: %repair-face-handedness. Again, a mesh check should confirm the problem is fixed.
I am not sure if these 'fixes' can be applied in Fluent 5- I guess you're using Gambit. It's worth a try.
Angus
Old   August 23, 2000, 10:52
Max Nutini
I sometimes have the same problem in 2d axysimmetrical cases where the axis is y=0. In that case it is enough to translate the whole domain of a negligible quantity (Dy = 0.001 for instance). See if this is your case... Bye Max
Old   August 24, 2000, 04:16
Javier Fernandez
Thank you all for information. It was very useful
Old   August 29, 2000, 00:37
Desmond Hui
For Non-positive volumes, I have the following suggestion to you.
Use Iso adaption to locate the cell of negative volumn and then use gambit to modify the mesh.
yours, Desmond
Grid check failed (non positive volumes). Muhammad Usman Qureshi FLUENT 5 September 26, 2013 06:26
[GAMBIT] Connecting volumes makaero ANSYS Meshing & Geometry 4 April 15, 2010 19:18
non positive volumes exist Moke FLUENT 1 July 7, 2006 08:20
union of volumes CHUBBY FLUENT 2 May 4, 2001 06:31
non positive volumes pankaj shukla FLUENT 4 December 6, 1999 09:42
