February 11, 2018, 13:10 |
Wake Behind Oscillating Airfoil_No Vortices
frantsesko
Rep Power: 8 |
Hallo my friends ,
I am trying to simulate, in Fluent 15.0 , an oscillating airfoil, in 2D, with the following characteristics : 1)NACA 64418 2)heaving amplitude =0.05 m 3)pitching amplitude =4 degrees 4)air inlet speed =26.4 m/s (Re=0.85 * 10^6) 5)chord =0.5 6)pivot point =chord/3 (from leading edge) 7)heaving eq. of motion :h=0.05*sin(2*pi*t) 8)pitching eq. : a=1+4*sin(2*pi*t) 9)time step = 0.001 s The turbulence model i am using is the Realizable k-e . In order to simulate the pitch and heave motion i use sliding mesh, which is attached to the airfoil , which moves also vertically (with magnitude of motion 0.05 m) . Mesh characteristics : 1)y+=1 2)1878 elements on airfoil 3)inflation with 30 layers and growth rate 1.2 4)170.000 elements in total The problem i am having is that in the velocity curl contours i cant see any vortices . (see attachment) Should there be any at this amplitudes of oscillating motion and velocity ? In the picture you can see the velocity curl field every 0.25T of the motion . Thank you very much in advance . |
February 14, 2018, 07:16 |
frantsesko
Rep Power: 8 |
Any Help ?
airfoil 2d, fluent, oscillating airfoil, vortices, wake |
Hairpin vortices in turbulent channel flow using DNS | Nitin Minocha | Main CFD Forum | 2 | November 21, 2016 17:52 |
having problems with implementing the wake rollup for a panel method | smilesgiles89 | Main CFD Forum | 0 | August 6, 2015 20:09 |
Initializing trailing vortices in fluent | zakir | FLUENT | 1 | February 16, 2014 07:54 |
Wake Vortices | dimitris340 | FLUENT | 0 | May 1, 2010 04:59 |
Cylinder Wake calculation | Adam Chapman | Main CFD Forum | 1 | January 30, 2007 12:54 |
