[Sponsors] | |||||
In my turbine runner computation I used multiple rotating frames of reference. I used only one rotating blade segment and stationary bladeless parts upstream and downstream. Unsteady solution converged well. When I solved the task as an unsteady one with relatively large time step (1*number_of_blades*rotating_speed) and task again converged well. When I used the shorter time step (0.1*number_of_blades*rotating_speed) the solution could not converged. Is there any restriction for the critical shortest time step in the unsteady computation?
Hi Ales, I have solved similar tasks with Multiple References Frame (MRF) and Sliding Mesh (SM) computational techniques for different type of turbines - Rushton, Pitch Blade and NS turbine - and I have solutions for these types of impellers with one and two turbine stirred tanks. In your question I do not understand what dimention do you use for rotating turbine, more precisly,
in your formula : 1*number_of_blades*rotating_speed what is the dimention of the rotating speed - rpm, rps or Hz ? Best regards, Peter Staykov |
Hi Peter, Thanks for your comment. The formula for the critical time step is dt=1/(rotational_speed * number_of_blades). The rotational speed is in round per second. It does mean, that the critical time step value is the same as the blade passing frequency. When I use the lower time step then the blade passing frequency, I could not obtain converged solution.
Best Regards. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
| Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM | 14 | October 27, 2010 11:13 |
| Intermediate step during a time step | Burn | OpenFOAM | 0 | July 16, 2009 10:01 |
| Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
| unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 11:32 |
