Home > Forums > FLUENT
Streamlines in 3D
Old   October 5, 2000, 08:07
Default Streamlines in 3D
SugIn
I don't get streamlines as an option when I use a 3D model. It works fine with the 2D model.
Old   October 5, 2000, 08:31
Default Re: Streamlines in 3D
Rüdiger Schwarze
The stream function is only defined in 2 d flows.
Old   October 5, 2000, 08:38
Pierluigi Allegro
The stream function is only defined in 2 d flows, in 3d you have pathlines.
Old   October 9, 2000, 02:22
Whitaker
When dealing with 3D probelms, people usually use the "path lines" under the "define" option to visulize the flow fields because the streamfunction defined in 3D space is a vector and can't be visulized as it's in 2D region.
Old   October 10, 2000, 14:51
m.girgis
The streamlines are the locus of the tangent of teh Velocity vector. They usually defined using the potential function which is derived using 2d analysis. So, if You want to define them in 3d problem, You have to define the planer streamlines in the three Planes (x-y, y-z and z-x) and then add them victorially. You get then the locus of the thengent of spatial (whole) velocity vector. The path lines are the pathes which the Fluid particle take during flowing in the Domain.
Old   July 10, 2009, 03:13
Mrt
MDinc is on a distinguished road
Murat
I also have same problem. I tried pathlines to see the flow trajectory but regarding the huge number of elements in domain, computer gets stuck and then I reboot it. How can I create streamline in 3D, how can I create three plane and add them to see the tangent velocity vectors?
Thanks,
Murat
MDinc is offline   Reply With Quote
Thread Tools
Trackbacks are On
[CFD Post] Surface streamlines not located where needed siw CFX 1 July 7, 2011 19:13
How to get Streamlines to interact.? stephen__white CFX 2 April 12, 2011 17:00
Streamlines under Moving reference frame; Spiral streamline from Tecplot aiqch Tecplot 2 October 30, 2009 00:27
Custom streamlines - only 2 velocity components bernarde STAR-CCM+ 5 August 24, 2009 07:18
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
