-   -   Importing from CAD package (http://www.cfd-online.com/Forums/fluent/27928-importing-cad-package.html)
SugIn October 5, 2000 08:09
As anyone had any experience importing a CAD file into Fluent 4.5 and above ? We all know about that geometric input is the longest part so I'm attempting this at some stage.
Kai Kang October 5, 2000 09:02
Re: Importing from CAD package
If you use AutoCAD, it works just perfect with the AcIS export/Import, because they use the same APIs...
SugIn October 5, 2000 10:51
Thanks for the tip. Getting AutoCAD is fine. Which version of Fluent have you used this in ? I'm using 4.5. But 5.3 and 5.4 is avialable.
Kai Kang October 5, 2000 10:53
I am using 5.3, for AutoCAD you need to export as AcIs file (.sta extension, if I remember right).
It is always better to simplify the geometry in CAD first...
Jack Keays October 5, 2000 11:03
Hi Kai,
The file extension for ACIS files is .sat
I had alot of problems with geometry. Exporting from Solidworks. Have you any ideas as to how this can be effectively done? Thanks.
Joern Beilke October 6, 2000 07:08
That file has to be imported into Gambit and not into Fluent itself.
Kai Kang October 6, 2000 09:36
you are right, should be Gambit instead of Fluent
Oliver October 6, 2000 15:13
Hi
Depending on the CAD software you are using, you can export the geometry as a variety of Standards
Pro Engineer STEP Solidworks STEP/SAT AUTOCAD, MDESKTOP SAT
If you have any problems, with the above formats, try and save them as a lower version, because there could be a inconstency between GAMBITS Translator and the version of the translator used in the CAD package
Regards Oliver
Daniel Malone October 25, 2000 10:52
Jack,
I operate a business, CAD Repair, that specializes in translating, healing and repairing CAD neutral files. I may be able to help you.
Dan Malone dpm@cadrepair.com 412-820-9205
