Post processing in FLUENT
Old   September 10, 2009, 01:05
Default Post processing in FLUENT
Praveen Kumar Jagarlapudi
praveen.jpk is on a distinguished road
Dear all,
I am giving pressure at inlet & velocity at outlet boundary conditions.
When i see the reports the results i get for total pressure(area weighted average) are:
at inlet 52.17 Pa
at outlet -1812 Pa
But when i see in the contour plot the values it is showing like from 87 Pa to -1812 Pa (major area) &-3120 Pa(At some small arears).
Forget about the outlet pressure because it is showing correctly that most of the arears with -1812 Pa.
But at inlet i am giving the inlet pressure as 52.17 Pa so,
why it is showing 87 Pa at the inlet areas.
Thanks & Regards,
Praveen
praveen.jpk is offline   Reply With Quote
Old   September 10, 2009, 01:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what kind of contour plot are you using for your comparison (static?, total?)
I would use velocity inlet and pressure outlet as BC
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Different in fluent result after post processing Niles FLUENT 0 August 14, 2008 04:28
Axial, Radial, Tangental velocity in FLUENT post Barri FLUENT 2 March 6, 2008 20:29
Fluent paralell processing in windows XP João Fernandes FLUENT 1 January 22, 2007 23:44
Parallel Processing by FLUENT? M Kermani Main CFD Forum 2 February 21, 2001 10:01
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
