Importing from CAD package
Old   October 5, 2000, 08:09
Default Importing from CAD package
SugIn
As anyone had any experience importing a CAD file into Fluent 4.5 and above ? We all know about that geometric input is the longest part so I'm attempting this at some stage.
Old   October 5, 2000, 09:02
Default Re: Importing from CAD package
Kai Kang
If you use AutoCAD, it works just perfect with the AcIS export/Import, because they use the same APIs...
Old   October 5, 2000, 10:51
SugIn
Thanks for the tip. Getting AutoCAD is fine. Which version of Fluent have you used this in ? I'm using 4.5. But 5.3 and 5.4 is avialable.
Old   October 5, 2000, 10:53
Kai Kang
I am using 5.3, for AutoCAD you need to export as AcIs file (.sta extension, if I remember right).
It is always better to simplify the geometry in CAD first...
Old   October 5, 2000, 11:03
Jack Keays
Hi Kai,
The file extension for ACIS files is .sat
I had alot of problems with geometry. Exporting from Solidworks. Have you any ideas as to how this can be effectively done? Thanks.
Old   October 6, 2000, 07:08
Joern Beilke
That file has to be imported into Gambit and not into Fluent itself.
Old   October 6, 2000, 09:36
Kai Kang
you are right, should be Gambit instead of Fluent
Old   October 6, 2000, 15:13
Oliver
Hi
Depending on the CAD software you are using, you can export the geometry as a variety of Standards
Pro Engineer STEP Solidworks STEP/SAT AUTOCAD, MDESKTOP SAT
If you have any problems, with the above formats, try and save them as a lower version, because there could be a inconstency between GAMBITS Translator and the version of the translator used in the CAD package
Regards Oliver
Old   October 25, 2000, 10:52
Daniel Malone
Jack,
I operate a business, CAD Repair, that specializes in translating, healing and repairing CAD neutral files. I may be able to help you.
Dan Malone dpm@cadrepair.com 412-820-9205
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 16:50
Recording Journa file: Importing CAD Geometry franzahir FLUENT 0 June 25, 2009 10:50
ploblem with importing CAD file into Star-Design caoll Siemens 0 March 17, 2008 20:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
