[Sponsors] | |||||
i am trying to generate grid for turbulent flow in a converging duct with curved boundaries.i want to know Whether the alignment with the flow direction is more important or minimum skewness is more important? Because i felt one has to compromise on one of these things. Any suggestions....
As you point it out, you have to make compromises! First it is obvious that you will never align your flow and your grid if you're using a triangular/tetrahedral mesh. So assuming that you're using quad/hex mesh then you will be able to align flow and grid. This could result in a decrease of the numerical diffusion (i.e. numerical error) but in simple flows. According to me, as numerical diffusion is not that high in convection dominated flows, you should better consider minimum skewness as "important factor" and choose a 2nd order scheme to solve the flow .
Regards |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| need help for generation grid | aya | FLUENT | 11 | March 4, 2008 14:46 |
| 3D Hyperbolic Grid Generation - Help Requested... | Marcus Lobbia | Main CFD Forum | 2 | November 9, 2003 05:53 |
| Help Re. Grid Generation | Patel Amit R. | FLUENT | 1 | February 28, 2003 21:27 |
| Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 04:59 |
| Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 04:07 |
