October 31, 2000, 20:18 |
Converging-Diverging part
Hi all, I try to analsys fluid film between flat plate and concave plate(so it has converging and diverging part) But the result says diverging part have negative pressure. It's somewhat stange to me I want to change this to seperation or other pressure value. How can I do?
Thanks, all |
November 1, 2000, 11:01 |
Re: Converging-Diverging part
I don't know if I understand your question but negative pressures are relativ to the operation pressure.
If this is not your problem please explain more detailed you geometry, the system (incompressible fluid properties, lam or turb. case etc.). Regards Phil |
November 1, 2000, 13:31 |
Thanks for your message. My system is fluid film formation between plate. It's incompressible and laminar flow. There is inlet and outlet.(have different pressure) The lower plate is flat as many simple problem. But the upper plate has geometry like parablic and it's center is located above the upper plate(so that is concave and has converging diverging part consecutively). There is pressure to support this fluid film. Due to this goemetry have converging and diverging part consecutively, there is negative pressure at the diverging part. So I want to find analysis method. One of this may be considering the seperation of the fluid film. Then how can I change the pressure value into the fluent?(I want to constrain the pressure will be same as separation condition)
November 17, 2000, 12:04 |
Phil, is that all turbulent flow is unsteady state?
Max |
December 15, 2000, 09:19 |
I do not understand what you are asking for?? So if you mean that turbulent flow is unsteady you are basicly right. This is caused by fluctuating values for each mean flow property. However you can simulate it assuming a steady state. Even if this is not right you get a result which is, if converged, a result of an unsteady flow.
Regards Phil |
Display Modes | |
Converging Diverging Nozzle in OpenFOAM | danishdude | OpenFOAM Running, Solving & CFD | 1 | September 15, 2012 01:12 |
[ICEM] How to mesh part by part? | rikio | ANSYS Meshing & Geometry | 6 | February 24, 2010 20:19 |
How to output data from stationary part only? | Aerolex | FLUENT | 0 | November 16, 2009 23:46 |
Any other way of converting a multi part to a single part avoiding ANSYS Design Model | LusoMundo | ANSYS Meshing & Geometry | 1 | May 14, 2009 15:35 |
Converging then Diverging Residuals??? | Erika Johnson | FLUENT | 8 | September 19, 2006 11:45 |
