-   -   Result interpretation (http://www.cfd-online.com/Forums/fluent/28017-result-interpretation.html)
Pilli November 15, 2000 13:53
Hello everybody, I have a flow with heat exchange over a wavy structure. The flow is turbulent! If I look on my Surface heat flux I have got high gradients from cell to cell in some parts. The problem is, if I compare overall values with experimental heat transfer data they are in good agreement, so that I think, that my mesh is sufficient enough for my case. Is it possible that because of turbulent eddies the heat surface heat flux is not very "smooth" from cell to cell?
Thanks for your help
regards Pilli
John C. Chien November 19, 2000 11:57
Re: Result interpretation
(1). You can find out the answer by refining your mesh, to see if it is still there. (2). Always try to refine the mesh first, then select different turbulence models and solution algorithms, to see how the solutions vary with respect to these changes.
Pilli November 19, 2000 17:58
Thank you and you are right, but the problem is that this project is nearly at the end. I have no time to restart the simulations. Anyway thank you for your help regards Pilli
