Home > Forums > FLUENT
reversed flow
Old   November 19, 2000, 15:41
Default reversed flow
Hakeem
Hi everyone, When I simulate my problem using FLUENT 5 the following message appears: reversed flow in 8 faces on outflow. What does this message mean ? how to go about it? Any suggestions
Old   November 20, 2000, 05:31
Default Re: reversed flow
alice
this means that you have a backflow effect in those faces. If you want to control this phenomenon, you have to choose pressure outlet instead of outflow as boundary condition.
Good luck
Alice
Old   November 21, 2000, 11:11
Petr
Hakeem,
Alice is right, but I would also recommend to look at your model if the outlet boundary is situated at suitable location. You should avoid backflow in any case (problems with convergence, difficult control of the fluid flowing into your solution domain through the outlet especially in the case of unsteady flow, etc.). Try to move the outlet to a more suitable place!
Old   November 22, 2000, 10:01
Default Re: reversed flow - thanks
Hakeem
Thanks alice and Petr ... I sorted out ...
Thread Tools
Trackbacks are On
reversed flow free FLUENT 4 February 27, 2014 02:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 05:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 09:05
