Buoyancy
Dear All,
I am now simulating air flow patern driven by buoyancy. Could anyone tell me what turbulence model should I use and what should I do with other definitions in fluent 4.5. Thanks a lot. |
Re: Buoyancy
Elton, we've gotten good results for buoyancy-driven air flows using the standard kappa-epsilon turbulence model. Don't use the Bousinnesq approximation with buoyancy unless you have really small temperature gradients.
Re: Buoyancy
Hi Evan,
Thanks for your response. Could you tell me what fluent code are you using because fluent 4.5 doesn't have standard Kappa-epsilon turbulence model. |
Re: Buoyancy
We've used FLUENT 4.32, 4.48, 5.1 and 5.4.8.
Kappa-Epsilon??
kappa-epsilon? Are you refering to the k-epsilon turbulence model based on kinetic energy and turbulent dissipation? If not, please provide a reference.
Thanks, Clinton |
Re: Kappa-Epsilon??
Yes, I got you. Kappa-epsilon is K-e turbulence model.
