January 24, 2001, 13:46 |
Journal files
Hi I'm trying to write a journal file, to allow me run fluent in parallel mode. I've proceeded as follows: File->Write->Start Journal In the main fluent window, I type something like rcd parallel.cas (iterate 300) wd parallel_300.cas File->write->Stop journal
My problem is that when I hit return after each command, fluent performs that action. So I have to wait for 300 iterations to finish the jornal file, which rather defeats the purpose! Also, it means that when I do run the journal it won't write properly, as the file parallel_300.cas exists already. Any help would be greatly appreciated! Thanks FP |
Display Modes | |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 14:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
CFX-Build journal files | KG | CFX | 2 | November 18, 2002 08:03 |
