January 29, 2001, 01:40 |
turbulent viscosity
Dear all,
I am trying to analyse the airflow inside a 2-D rectangular box with the air entering under pressure through a large hole from the side and exiting through lots of little holes at the top. The airflow inside is very turbulent and swirls around a lot. When the realizable K-e viscous model is used a message stating that the "turbulent viscosity limited to viscosity ratio of 1.00e+5 in 362 cells" occurs. As the number of iterations proceeds the number of cells affected increases. My question is what is causing this to occur, is it affecting the results, and if so how can it be removed. Any other ideas on solving this problem would also be greatly appreciated. This also occurs when using the other K-e models and the Reynolds Stress viscous models. The BC's are a pressure inlet and outlet using fluent 5.0. Thanks Warren |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 17:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
