February 6, 2001, 04:45 |
Help in Phase-Change Problem
I was trying to start with the phase change problem using FLUENT 5.3.18 and I follow the setup procedure (Phase Change Setup). After activating the: Define-->Models-->Energy from the menu and typing the: define-->models-->melt-freez and typing y [yes] for the yes and no question and I received a message :
Error: CAR: invalid argument [1]: wrong type [not pair] Error Object: #f. Does it means that the Fluent version in our department didn't support the phase-change problem? Because from the help menu file that I have read I should be able to solve phase change problem. Thanks for consideration on my problem. |
February 7, 2001, 01:17 |
Re: Help in Phase-Change Problem
Hi, Just answer my self. The problem has been solved. You need to open the mesh first before changing the parameter of the melt-freez parameter (mesh.msh file). Thanks
Display Modes | |
simulation of phase change material melting | rosol | FLUENT | 4 | December 8, 2015 07:56 |
Solid/liquid phase change using large viscosity | gregor.vidmar153 | OpenFOAM Running, Solving & CFD | 3 | June 10, 2010 06:31 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 06:27 |
thermal phase change | serdar | CFX | 3 | May 3, 2005 06:50 |
Phase change process | Sang-jin Lee | Siemens | 5 | December 5, 2001 05:17 |
