Home > Forums > FLUENT
Gambit meshing
Old   February 8, 2001, 12:58
Default Gambit meshing
FP Mie
Guys I'm trying to mesh the surface only of a 'torpedo' shaped object. The volume was created by drawing half of a 2D airfoil, and rotating it about 360, about the x axis. When I try to mesh it, no matter what interval count I use, the mesher goes to 99% done, and then the number of elements climbs to 100000, and the program seems to stop. Has anyone had this problem ,and if so, does anyone know how I should try meshing it? Thanks in advance FP
Old   February 9, 2001, 08:07
Default Re: Gambit meshing
Harry
i think you should divide your object into pieces, then try to mesh in coarse mesh
Old   February 9, 2001, 12:37
Shyam Kishor
You should change the default to increase the number of triangles allowed (100,000) on a single geometrical face. EDIT Defaults -> Mesh -> Trimesh -> Max_faces. You can either assign a higher value or "-1", which means no limit.
Thread Tools
Trackbacks are On
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 06:04
