solidification
Old   February 14, 2001, 14:39
Default solidification
Damien
I am trying to model a phase change problem with Fluent and compare it to published data and the Stefan solution just to test Fluents accuracy before I proceed with a more complex problem. I have run test cases with solidification turned on and compared it to a pure conduction problem with exactly the same boundary conditions. The results showed the temperature profiles were the same. I was expecting the phase change problem to account for the latent heat and show a difference in the temperature profile. The only use I can see in using the phase change feature in Fluent is to graphically display the percentage of the liquid and solid region. I have tried many different cases and cant see how Fluent incorporates the latent heat in the phase change problem. I would appreciate any responses of your experiences with these types of problems.
tracking the solidification front Kuba FLUENT 1 May 25, 2018 03:06
About the solidification? H.P.LIU Phoenics 1 December 1, 2010 09:49
Restart a solidification with previous solidifation data in v9.4 jk75 FLOW-3D 2 August 28, 2010 21:40
Restart for Solidification atulverma FLOW-3D 3 May 6, 2009 17:40
Solidification problem: viscosity ratio limited Deepak FLUENT 0 December 11, 2008 13:08
