Home > Forums > FLUENT
k-epsilon turbulence model
Old   February 24, 2001, 15:38
Default k-epsilon turbulence model
David C
In Fluent 5 I am performing analysis on a RAE-2822 aerofoil - transonic turbulent case using the k-epsilon model.
I know from experimental data under the conditions I am applying, that the flow transitions to turbulent at about 10% chord.
As the model is set up currently the flow is turbulent (using a turbulent flow model) from the start, i.e. at the far-field. This is distorting the leading edge pressure results.
Is there a way of making Fluent model this flow correctly i.e. only applying the k-epsilon model after 10% chord (or at any position I choose)?
Has anyone got any advice? Thanks
Old   February 25, 2001, 12:53
Default HELP - SAME PROBLEM
MIKE LONG
Old   February 26, 2001, 02:19
Default Re: HELP - SAME PROBLEM
Hassid Samuel
k-epsilon cannot be expected to model transition if this is what you ask - you should at least try RNG.
Old   February 26, 2001, 11:48
Default Re: k-epsilon turbulence model
Volker Pawlik
if you really want to model an abrupt transition from one cell to the neighbour one just split your domain into two fluid zones and turn on "laminar zone" for the first. Then the the k- and the epsilon-equation are frozen inside this zone.
Thread Tools
Trackbacks are On
Two-Layer k-Epsilon Turbulence Model james.t OpenFOAM Programming & Development 8 March 25, 2016 02:34
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 13 November 4, 2013 15:13
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 09:53
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 05:15
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
