separating fluid regions
Old   February 28, 2001, 18:20
Default separating fluid regions
David C
Hi
I am trying to separte a fluid region (flow around aerofoil) so I can set the flow in one region to laminar to help model transition.
How can I separate the fluid into two zones? Is this done within Fluent or to I need to return to the pre-processor?
Thanks
Old   March 7, 2001, 10:52
Default Re: separating fluid regions
Volker Pawlik
Hi David,
you can separate fluid zones inside Fluent by using the "adapt by region" tool: Method 1
1. select a region (adaption/ region adaption) 2. separate cells / by marked cells (the cells you have chosen during step 1 will be shown under 'registers')
or
Method 2
you create two fluid zones inside your pre-processor. This is the recommended way if you are using tetrahedral cells, since it is impossible to get a sharp separation of the two fluid zones with this type of cells by using method 1.
Volker
Questions of fluid pairs fjalil CFX 1 June 10, 2009 17:36
Fluid pairs fjalil Main CFD Forum 0 June 10, 2009 13:47
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
