Home > Forums > FLUENT
gambit-merge vs. unite
Old   March 7, 2001, 02:02
Default gambit-merge vs. unite
sean
Guys, do u know what is the difference between command "merge" and "unite" in Gambit?
Old   March 7, 2001, 03:42
Default Re: gambit-merge vs. unite
x.tang
hi,sean,"unit" is that two or more faces (volumes) unit into one REAL face (volume). "merge" is that two or more faces (volumes) merge into one VIRTUAL face (volume).
Old   March 7, 2001, 05:04
sean
however, I saw the "real" or "virtual" option in the merge command form
Old   March 7, 2001, 12:02
Shyam Kishor
Real merge option is available in case of volumes. Real merge requires volumes to be connected (i.e. must have a shared face) where as real unite will work for two or more intersecting (connected/disconnected) volumes. Also, topology of the resulting volume would be different in each case.
Old   March 7, 2001, 13:24
Kai Kang
For the difference in topology of Merge and Unite commands, how does it affect the following meshing?
This has been confusing me awhile, too
Old   March 7, 2001, 17:49
Shyam Kishor
Merge deletes the shared connected face but leaves all other faces of the original volumes unchanged.
Unite may also unite other faces in addition to deleting the shared face (if any).
Old   March 7, 2001, 21:47
sean
For grid, are the above mentioned the only difference between "merge" and "unit"?
Thread Tools
Trackbacks are On
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Merge blockMesh and Gambit, failing at zones kjetil OpenFOAM Native Meshers: blockMesh 0 December 7, 2009 09:52
Gambit :The differences between merge & unite ? bambang FLUENT 1 August 5, 2001 09:22
The differences between Merge & Unite in Gambit? bambang FLUENT 0 July 29, 2001 11:41
GAMBIT merge and export mesh sean FLUENT 4 March 8, 2001 08:50
