UNSTEDY FLOW OVER A CIRCULAR CYLINDER
Old   February 2, 2001, 07:30
Default UNSTEDY FLOW OVER A CIRCULAR CYLINDER
sanjib das sharma
Hi,I am stuck with a pretty easy problem!.I can't solve viscous flow over a circular cylinder..I'm not getting the Karman vortices,and vortex shedding....also the solution in the turbulence regime is not at all correct....any suggestions?????? Thanks to all who answers, Sanjib.
Old   February 6, 2001, 01:27
Default Re: UNSTEDY FLOW OVER A CIRCULAR CYLINDER
kenn
what method are you using????
Old   February 6, 2001, 01:28
kenn
sorry, I didn't notice this is Fluent section.
Old   February 11, 2001, 12:19
John C. Chien
(1). If you don't know how to solve the problem, then you need to take a CFD course first and find out whether it is possible to solve the problem or not. (2). If the turbulence model is not giving you the correct answer, you need to do some research in turbulence modeling and find out whether you need to improve the model or not. (3). If you are using a commercial code, then you should get a sample case from the vendor first before you attempt to solve your problem. Ask the support engineer to show you how to solve your problem, otherwise, try some other codes or write your own.
Old   March 16, 2001, 01:22
Chetan Kadakia
Does your solution converge? What are your boundary conditions? Which turbulence model did you choose?
Old   March 16, 2001, 01:49
sanjib das sharma
Hi Chetan,
yes,the solution converged.the boundary conditions were,velocity inlet,pressure outlet,symmetry,and wall at the cylinder surface.the turbulence model is k-e. did you get the results?please inform if you did so.
Sanjib.
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
Which Solver/Model to use for flow over Circular Cylinder ? Re [1 , 10^6] WolfgangS. OpenFOAM Running, Solving & CFD 1 December 6, 2010 02:48
3D FLOW OVER A CIRCULAR CYLINDER Srinivas Mettu FLUENT 2 April 4, 2010 22:11
flow past a circular cylinder Senthilkumar Main CFD Forum 2 April 19, 2009 23:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
