March 25, 2001, 01:39 |
Gas Dispersion in Water Column
We have a system of a jet of gas bubbling through a liquid column. Which version of multiphase model is most appropriate? Am I correct in assuming that the VOF model should not be used and we should better use the ASM model? Another related query is that how do you compare Fluent 5.4 and Fluent 4.5 in solving such problems? Any suggestion is welcome.
March 27, 2001, 04:24 |
Re: Gas Dispersion in Water Column
I think that you'd better use the ASM model even if this one has proved its limits. The vof is reserved for single bubbles and is not appropriated for gas plumes. The better you'll find is the Euler-Euler model from Fluent 4.5
Eric |
March 27, 2001, 07:28 |
Eric, you talked of the limits of the ASM model. Please tell me what they are w.r.to VOF. Is it anything else other than convergence?
Display Modes | |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Liquid water, gaseous water and another gas | Andy | FLUENT | 1 | May 22, 2006 09:51 |
Hot gas bubble collapse in cool water | William Palm | FLUENT | 1 | April 20, 2005 11:53 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
