Home > Forums > FLUENT
meshing an annulus
Old   March 27, 2001, 05:08
Default meshing an annulus
atholl
Can anyone suggest any strategies for meshing a concentric annulus in GAMBIT? I've been playing about with edge meshing the boundary layers up until now and was wondering if there are any better methods.
Old   March 27, 2001, 07:51
Default Re: meshing an annulus
Anthony Wachs
I am currently working on annular geometries including concentric ones. My strategy is to cut the annular in two equal volumes (two half annulus), following the axial direction and to mesh similarly those two parts. With this solution, you are able to prescribe the mesh refinement in the radial direction, as also in the axial direction. Finally, when I have meshed five of the six faces of each volume (the remaining unmeshed face is one of the two annular sections of the pipe), I use the Cooper scheme to project the mesh of the annular section in the whole volume.
If you'd like to see an example, do not hesitate to contact me on my personal email
I hope that will help you Sony
Old   March 27, 2001, 10:37
Ashutosh
The meshing strategy will depend on the type of flow problem you are solving. If you are expecting BL on the annulus walls then you may have to refine the mesh near the wall by applying Boundary layer. Then you can mesh using Cooper meshing scheme taking the two concenteric faces( radial faces) as source faces. This way you don't need to divide the volume into two as done by Anthony. Are you solving 3D or 2D problem? With Cooper you can get the good quality mesh.
Bye!
Ashutosh
Old   March 27, 2001, 11:50
atholl
Thanks for the quick replies! I'm modelling in 3-D and have tried applying a boundary layer at the walls, but cannot seem to get good aspect ratio on the cells without having an excessively high interval count on the edges, which as a result takes a very long time to cooper the volume. Is there any way around this?
Thread Tools
Trackbacks are On
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
