UDF in fluent
Old   March 27, 2001, 18:22
Default UDF in fluent
KRISHNA SAMPATH
I am a graduate student modeling the flow of air through a rotary valve in an IC engine using fluent. I have the following question. The pressure at the outlet varies as the density of air changes. I would like to use this value of density at the current time step to calculate the pressure at the next time step. I am able to write out the density values into a *.out file. Could someone please tell me how I could read this value back into my UDF and calculate the pressure for the next time step.
Thanks.... -Krishna
Old   March 29, 2001, 03:20
Default Re: UDF in fluent
Seyoung Oh
In your case, it's better to use a "C_UDMI" function. By using that you can write a density values in a memory stack and use it in your UDF. So, writing the density values into a file and reading it from the file is not required.
Your UDF can be,
DEFINE_ADJUST() { Thread *t=Lookup_Thread(domain,outlet_id)
/* you can find the outlet id in fluent menu-define-boundary condition */ begin_c_loop(c,t) {
C_UDMI(c,t,0)=C_R(c,t); /* write values in memory stack */ }
/* use it to update the pressure */ DEFINE_PROFILE() { F_P(f,t)= C_UDMI(c,t,0)*R*T; /* exam. p=rho*R*T */ }
And don't forget to select a adjust function in the fluent menu(defined-function Hooks-Adjust function) to update the density at every time step.
Good luck..
Seyoung
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
Transient pressure UDF for parallel fluent droberts Fluent UDF and Scheme Programming 5 October 11, 2010 04:13
Using Fluent with a UDF frm a remote m/c aarti FLUENT 2 September 11, 2008 19:53
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
Can somebody send me a Fluent 6 UDF manual?? KKLAU FLUENT 4 April 14, 2004 16:37
