-   -   Is this UDF correct? (http://www.cfd-online.com/Forums/fluent/28409-udf-correct.html)
JJ April 4, 2001 03:36
Hi all,
I am a novice in C programming, I wrote the following in an attempt to generate a two layer flow in my domain. But when I try to compile it, fluent keeps giving me error msg. Not sure what is wrong. Can anybody help? Thanx.
#include "udf.h"
DEFINE_PROPERTY(cell_density, cell, threads) {
real density;
real grid_y = NODE_Y(c,t);
if (grid_y<0.81)
density = 998;
else
density = 968;
return density; }
Regards, JJ
Greg Perkins April 4, 2001 04:27
Re: Is this UDF correct?
try grid_y = NODE_Y(cell,threads);
JJ April 6, 2001 07:08
Hi Greg,
Thanx for your help, tried it and I was able to compile it. But I am still stuck cos when I try to initialize the flow, I obtain the following error msg "2ldensity.cpp:6: macro `NODE_Y' used with too many (2) args"
2ldensity is the name of the UDF. May I know what can be done?
Thanx in advance.
JJ
Greg Perkins April 8, 2001 18:54
Actually you'd be better to use C_CENTROID to determine the location of the cell centroid. Check this out in the udf manual.
Greg
