Home > Forums > FLUENT
What is Floating pt error??
Old   April 14, 2001, 06:09
Default What is Floating pt error??
JJ
Hi there,
I was prompted with the following error message by Fluent when I try to plot concentration contour on one particular plane in the domain,
Error message: "Floating point error : overflow"
What does it mean? I am able to plot and do other things except ploting on that plane! The solution is already converged.
Thanx.
JJ
Old   April 16, 2001, 15:30
Default Re: What is Floating pt error??
Scott W
I've seen that occur when a plane lies just outside the domain. For example if you have a boundary at x=0, and then create a surface of constant x at x=0. This should lie right along your domain boundary. However, due to rounding errors, Fluent thinks the domain is at x=0+ (such as x=0.00000000000001) and you are trying to display outside that domain at x=0.00000000000000.
Old   April 17, 2001, 01:42
Default Re: Can the solution be trusted?
JJ
Hi Scott,
Thanx for the answer.
Since this seems to be a prob with the grid that I have drawn, does it imply that the solution obtain with it could not be trusted?
Cheers JJ
Old   April 17, 2001, 09:39
Scott W
There are two ways to trust your solution: 1) Compare parts of it to experimental data. If they match within your tolerance, then you can trust your solution. 2) While not quite as good, compare your answer to simple analytical solutions. If there are major discrepancies then either your solution is wrong, the analytical solution doesn't model reality, or both.
Unless you have the simpliest of all geometries, the mesh will not exactly mesh the geometry you created. For example, draw a curve on a piece of paper and hand-mesh it with rectanges. You have either 1) mesh points outside the curve domain or 2) the mesh doesn't fully reach the edge of the domain. The finer the mesh, the better the approximation, but you can never fully mesh the curve until Fluent lets us have curved edges on our cells. It is up to you to compare your CFD results to something else to determine if this is a problem.
Old   April 18, 2001, 03:43
Default Re: thanx!!!
JJ
Scott, thanks a lot for your answer, they were a great help!
Cheers JJ
Thread Tools
Trackbacks are On
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
