April 17, 2001, 15:36 |
Change or delete the materials type: Al
Hi, Currently I am modelling a combustion of methane in a cylinder chamber. When I want to delete and changed the materials type: Al to Steel material, the material type Al could not be deleted.
Can anybody assist me, how to change or delete it. If could not deleted, does material Al during the calculation effect the result calculation, since I need the steel type as the boundary condition. Every suggestions are welcome! Regards Adi |
April 18, 2001, 07:59 |
Re: Change or delete the materials type: Al
hi sure it will effect your results to change the material type go to define-material then material type as a sold then press database select sold again pull down the sold material database you will find stell if this is the properties you looking for this good if it is not make all the changes in the properties then press change/create. in boudray condition change the sold zone to stell. good luck
April 18, 2001, 21:09 |
Hi Hassan Thanks for the responds. Before you sugested it, I have done the same procedure. But the material type ie.:Al still apears, it could not be deleted. What I want is, the Al material deleted then changed to steel material.
Now I am thinking, even the Al may not deleted from the display panel then follow the procedure you have mentioned, is the new material ( ie.: steel) will take effect? Looking forward for the responds. Cheers! |
April 18, 2001, 23:31 |
I think you need to make sure the material is not being used by any zone - then it can be deleted or changed.
April 19, 2001, 08:08 |
Hi i didn't understand why you insisted to delet Al leave it but just change the solid in B.C to steel and that's it . have anice day
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
Higher order convection schemes with unstructured grids | vkrastev | OpenFOAM | 29 | April 5, 2018 03:23 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
