May fluent can simulate heat and mass transfer?
Old   April 21, 2001, 11:14
Default May fluent can simulate heat and mass transfer?
yueroo
Hi: I want simulate heat and mass transfer to drying grass but I don't want simulate fluid flow. That is I want to solve heat and mass equation . can FLUENT do it ? Thank you very much?
Old   April 23, 2001, 04:01
Default Re: May fluent can simulate heat and mass transfer
Harry Qiu
Hi, Only one suggestion.You can try. set the velocity of the inlet is 0. Harry.
Old   April 24, 2001, 10:04
Xiao Hu
I don't think you can solve the problem without simulating the flow. The reasons are as follows:
Temperature and mass fraction distribution will make density non-uniform, which in turn will cause flow due to gravity (natural convection). Diffusion process is much slower than convection. In other words, convection, even though only natural as opposed to forced, will make larger contribution to mass transfer than diffusion. Therefore, unless you can justify that natural convection in your case is small, you can not predict right mass transfer without solving the flow.
Old   April 24, 2001, 11:19
yueroo
Hi Thanks for your suggestion. I want to get temperature distribution in grass. My grass is very tight, and only water will evaporization .(by heat) so I want to simulate heat condition, and mass diffusion. I think your suggestion I will try to do it . Can fluent simulate heat and mass and gas transfer in solid matrial ? I only see it can simulate fluid in mass and heat and momentem transfer. Thanks!!!!
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 01:49
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 03:01
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
