BC's through journal file
Old   April 24, 2001, 11:43
Default BC's through journal file
Sandeep
Hello all, I have a case file where in I need to specify the exact same boundary condition to 100 different faces within a geometry. Is there a way to do this through a journal file in fluent v5.5 ?
Old   April 25, 2001, 13:44
Default Re: BC's through journal file
Xiao Hu
Try a UDF or a profile. A journal file won't help you this time.
Old   April 26, 2001, 15:24
Lanre
Try: 1. Use the "Copy..." BC feature in the Define-->BC panel. Define the BCs for one of the faces and copy to the rest. 2. Use a scheme routine to loop through the zone id's
Old   April 26, 2001, 15:26
Sandeep
Thanks !
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
