Home > Forums > FLUENT
???Flame extinct (Methane-Air)
Old   April 24, 2001, 22:18
Default ???Flame extinct (Methane-Air)
Harry Qiu
Dear Mr. or Mrs:
I'm modeling premixed laminar combustion for methane/air.
I meet a great difficulty --> At the beginning of iteration, I set the Cp as constant(1000J/kg.k), then the flame front is basically formed as the iteration proceeds. But the temperature of the flame is too higher than 3000k. So in order to reduce the flame temperature to the reasonable level, I set the Cp as "Mixing Law", but the flame will be extinct soon after I set the Cp as "Mixing Law".
Can you tell me why?
Thank you. Sincerely yours, Harry.
Old   April 25, 2001, 10:34
Default Re: ???Flame extinct (Methane-Air)
Steven Smith
In addition to using the "mixing law" for the methane-air mixture, I suggest you verify the specific heat for each specie in the flowfield is defined using the piecewise-polynomial option.
Old   April 26, 2001, 09:32
Harry Qiu
Hi,Steven:
Thank you for you reply. I do have set the specific heat for each specie in the flowfield as piecewise-polynomial(by default value). do you have any other suggestions? Thank you.
Thread Tools
Trackbacks are On
How to give different flow velocity to air and methane at the same inlet?? dharanishb FLUENT 3 June 13, 2011 14:52
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
modelling of flow between methane and air satya FLUENT 5 April 3, 2009 06:32
Lean swirled premixed combustion methane air bisounours FLUENT 0 July 4, 2007 06:52
kinetic data for methane air global reaction James FLUENT 0 March 11, 2006 16:33
